Associating Help Messages with Scroll Areas, Grids, and Group Boxes
After entering a message, you associate the message to a page control. To associate help messages to scroll areas, grids, and group boxes:
  1. Open a page definition.
  2. Double-click the scroll area or grid to access the properties dialog box.
  3. Access the Label tab.
  4. In the Embedded Help Popup section, select the Message Catalog Popup option.
  5. Enter the Message Set/Number values of the message that you want to appear in the embedded help pop-up page.
    The message should appear in the Text field.
  6. Verify that the message in the Text field is correct.
  7. Click the OK button.
  8. Save the page definition.
  9. In the browser, access the page and test the embedded help.
Use the preceding steps to associate Help messages to group boxes, too.
