Setting General Properties
Access the Record Properties, General tab.
| Field or Control | Description |
Description |
Enter a descriptive name for the record. |
Record Definition |
Enter appropriate comments in this area, including details about the record type, use, parent and child relationships, or other information that is important to other application designers. |
Owner ID |
Displays a list of applications with which this record is used. This list is helpful to identify the applications with which the record is associated during application development. |
Last Updated |
Displays the date and time of the last modification that was made to the record and the name of the user who made the modification. |
Runtime Definition |
Displays whether the record definition was created as a runtime definition by the PeopleCode Language Reference: CreateRecordDefn function PeopleCode built-in function. A runtime record definition is not editable in Application Designer. In addition, it cannot be used in design time definitions (such as pages, components, or others) in Application Designer. However, a runtime record definition can be added to a project definition. |
