Setting General Properties
When you create or make changes to a menu, you should document the changes for future reference. You can do this on the General tab of the Menu Properties dialog box.
| Field or Control | Description |
Description |
Enter a descriptive name for the menu. |
Comments |
Add a description of the menu or any other useful information. |
Owner ID |
View a list of applications with which this menu is used. This list is helpful to identify the applications with which the menu is associated during application development. |
Last Updated |
View the date and time of the last modification and the name of the user who made the modification. |
