Application Engine Program Types
Application Engine has five types of programs. You specify the type in the Program Properties dialog box for your program definition. The types are:
  • Standard, which is a normal entry-point program.
  • Upgrade Only, which is used in PeopleSoft upgrade utilities.
  • Import Only, which is used by PeopleSoft import utilities.
  • Daemon Only, a type of program used as a daemon process.
  • Transform Only, a program type used to support Extensible Stylesheet Language Transformations (XSLT).
