Caching the Application Engine Server
Application Engine caches metadata just like the application server. This caching enhances performance because a program can refer to the local cache for any objects that it uses.
Cache Directory Location
Application Engine programs that run on a Microsoft Windows NT or UNIX server lock their own cache directory for the duration of a run. You find these directories under the master cache directory. The master directory is created under the directory specified by the CacheBaseDir variable in the PeopleSoft Process Scheduler configuration file. If all existing cache directories are locked, a new one is created. Cache subdirectories are named sequentially, starting at 1.
If you do not enter a fully qualified path for the CacheBaseDir variable, then Application Engine creates a cache directory within the directory in which the program is set to run.
Do not share the CacheBaseDir variable with application servers and do not use environment variables when specifying CacheBaseDir because the system does not resolve them. For example, do not set CacheBaseDir to $PS_CFG_HOME.
Cache Parameters
The PSPRCS.CFG (PS_SERVER_CFG) file has two additional cache parameters. They are:
Enable Server Caching
Server Cache Mode
Do not alter these settings from the delivered defaults. These settings are reserved for future use.
