Enabling Application Engine Tracing
By default, all Application Engine traces are turned off. To see a trace or a combination of traces, set trace options before you run a program.
  • Set command line options.
  • Set parameters in server configuration files.
  • Set client options in Configuration Manager.
  • Enable selective tracing
