Using Application Engine Meta-SQL
This section describes the meta-SQL constructs, functions, and meta-variables you can use in Application Engine.
The SQL Editor does not validate all of the meta-SQL constructs, such as %Bind and %Select. Messages might appear stating that these constructs are invalid.
