Using PeopleCode Examples
The following topics provide examples of common ways that you can use PeopleCode within Application Engine programs.
Do When Actions
Instead of a Do When action that checks a %BIND value, you can use PeopleCode to perform the equivalent operation. For example, suppose the following SQL exists in your program:
%SELECT(EXISTS) SELECT 'Y' FROM PS_INSTALLATION WHERE %BIND(TYPE) = 'X'),
Using PeopleCode, you could insert this code:
If TYPE = 'X' Then
Exit(0);
Else
Exit(1);
End-if;
If you set the On Return parameter on the PeopleCode action properties to Skip Step, this code behaves the same as the Do When action. The advantage of using PeopleCode is that no trip to the database occurs.
Dynamic SQL
If you have a Select statement that populates a text field with dynamic SQL, such as the following:
%SELECT(AE_WHERE1)
SELECT 'AND ACCOUNTING_DT <= %Bind(ASOF_DATE)'
You can use this PeopleCode:
AE_WHERE1 = "AND ACCOUNTING_DT <= %Bind(ASOF_DATE)";
Sequence Numbering
If you typically use Select statements to increment a sequence number inside of a Do Select, While, or Until loop, you can use the following PeopleCode instead:
SEQ_NBR = SEQ_NBR + 1;
Using PeopleCode rather than SQL can affect performance significantly. Because the sequencing task occurs repeatedly inside a loop, the cost of using a SQL statement to increment the counter increases with the volume of transactions your program processes. When you are modifying a program to take advantage of PeopleCode, the areas of logic you should consider are those that start with steps that run inside a loop.
You can also use the meta-SQL constructs %Next and %Previous when performing sequence numbering. These constructs may improve performance in both PeopleCode and SQL calls.
Rowsets
You can use rowsets in Application Engine PeopleCode; however, using rowsets means you will be using PeopleCode to handle more complicated processing, which degrades performance.
Math Functions
Use the math functions that your database offers whenever possible.
Internally, PeopleCode assigns types to numeric values. Calculations for the Decimal type are processed in arrays to ensure decimal point uniformity across hardware and operating system environments. This processing is much slower than calculations for type Integer, which are processed at the hardware level.
When PeopleCode converts strings to numeric values, it does so using the internal Decimal type. For performance reasons, avoid calculations using these values.
A third type of numeric value is the Float type. It is not used as frequently for the following reasons:
Constants are never stored as Float types in the compiled code.
For example, 2.5 is always Decimal type.
The only way to produce a Float value is by using built-in functions, such as Float or the Financial math functions.
Use the Float type to produce a float result only if all operands are also of the Float type. Float operations occur at the hardware level.
PeopleCode does not offer optimum performance when processing non-Integer, non-Float math calculations. To perform calculations with these numeric types, consider allowing the database to perform the calculations in COBOL.
PeopleCode supports a range of mathematical functions and numeric types. In general, if a complex calculation is run repetitively in an Application Engine program, you should carefully analyze whether to perform the calculation in a PeopleCode action or use the relational database management system (RDBMS) functions through a SQL action. Using SQL may require PeopleSoft meta-SQL to handle platform differences, but it may be the most efficient way to update field values. If SQL is not appropriate, consider numeric typing in PeopleCode, as it affects the speed and accuracy of the calculation.
SQL Class
Instead of using the SQL class within PeopleCode, have Application Engine issue the SQL and use a Do Select action that loops around sections containing PeopleCode actions.
Coding all of the logic within a single PeopleCode program might appear to be easier, but splitting the logic into smaller pieces is preferable because you will have better performance and will get more detailed commit control. Within a PeopleCode program, you can commit in certain cases using the CommitWork function. You can always issue a commit between Application Engine steps.
See PeopleCode Language Reference.
See PeopleCode API Reference: Understanding SQL Objects and Application Engine Programs.
Arrays
Instead of using arrays in Application Engine PeopleCode, explore the use of temporary tables for storing pertinent or affected data. Arrays offer the following advantages:
Data is available for restarts.
An RDBMS is efficient at managing and searching tables.
Temporary tables lend themselves to set-based processing.
You can use the Statement Timings and PeopleCode Detail Timings trace options to generate an Application Engine timings report to determine whether your program is spending significant time processing arrays.
