Using the Zoom Options
You can adjust the display of Application Engine programs with zoom in and zoom out options.
Access Zoom In and Zoom Out from the View menu option.
When you zoom to the maximum or minimum, a warning message is displayed.
Shortcut key for zoom in is F8 and zoom out is Alt F8.
