Running the PSXPCLEAN Application Engine Program
The PSXPCLEAN application engine program is delivered in Report and Delete mode. To run the program in Report Only mode, open the application engine program PSXPCLEAN in Application Designer and remove the comment in the following statement in PSXPCLEAN:Main:Start PeopleCode action:
rem PSXPFILECLN_AET.REPORT_ONLY_FLAG = "Y"You can schedule and run PSXPCLEAN using the PeopleTools, Process Scheduler, System Process Request page. You should run this program on a regular basis to keep template metadata consistent.
