Using External Fonts
To use fonts other than those that are pre-defined, you need to create a font mapping in the fonts section of the xdo.cfg file.
See Defining System Properties, for details on xdo.cfg file.
This is an example of font mapping syntax for RTF templates:
<config version="1.0.0" xmlns="http://xmlns.oracle.com/oxp/config/">
    <properties>
        <!-- System level properties -->
        <property name="xslt-xdoparser">true</property>
    </properties>
    <fonts>
        <font family="Arial" style="normal" weight="normal">
            <truetype path="C:\Windows\fonts\arial.ttf" />
        </font>
	<font family="Arial" style="normal" weight="bold">
            <truetype path="C:\Windows\fonts\arialbd.ttf" />
        </font>
    </fonts>
</config>
This is an example of font substitution syntax for PDF templates:
    <properties>
    </properties>
    <fonts>
        <font-substitute name="Helvetica">
           <truetype path="C:\Windows\fonts\calibri.ttf" ttccno="0" />
        </font-substitute>
    </fonts>
</config>
See Oracle Fusion Middleware Administrator's Guide for Oracle Business Intelligence Publisher, “Appendix C Configuration File Reference”, “Font Definitions,” for additional details on the font mapping syntax.
