Populating Rowset-Based Message Parts in Container Messages
The Handler Tester utility enables you to populate rowset-based message parts in container messages.
When you select a container message with which to work in the Handler Tester utility, a Container Message Builder link appears on the Handler Tester page.
This example shows the Handler Tester page with a service operation selected that contains a container message that contains rowset-based message parts.
Handler Tester page
The example shows that the service operation IB_EX_MP_ROWSET_SYNC is selected to test. The service operation contains the message IB_EX_ROWSET_CONTAINER, which is a container message comprised of rowset-based message parts.
When you select the Container Message Builder link, the Container Message Page (IB_MSGCONTAINER) appears.
This example illustrates the fields and controls on the Container Message Builder page.
The example shows the first message part contained in the message container, IB_EX_ROWSET_PART1.V1. At the bottom of the page is the familiar tree structure for building out rowset-based messages. You use the same pages as you would to build out any rowset-based message.
Use the backward and forward arrows to navigate to the different message parts in the message.
In between the navigation arrows, the system displays the part on which you are working and the total number of parts in the container message. This example shows that the Container Message Builder page is displaying message part one and that a total of two parts comprise the container message.
The procedures for creating and modifying rowset-based messages is described in detail elsewhere in the PeopleTools product documentation.
