Defining ADS Project
To define a new project:
The initial state is New Project. Add a description and comments.
Select a data set.
When you tab off the data set name, the Insert Data Set Content page is displayed for that data set.
Select the data set content.
Save the project. The new status is Created.
Additional data sets can be added to the project.
Use the Project Definition page to define the ADS project.
Navigation:
This example illustrates the fields and controls on the Project Definition page. You can find definitions for the fields and controls later on this page.
| Field or Control | Description |
Description |
Enter a description for the project. The description should include information about the project. |
Comments |
Optionally you can add comments to the project. |
Project State |
Display only field that shows the current state of the project. You can use the Refresh button to obtain the most recent state. Progress state on the source will show:
Progress state on the target will show:
Validation errors, if any, are also shown. |
Progress |
Display only field that shows the progress of the project copy or compare. |
Data Set Name |
Select one or more existing data sets from the lookup. Look up will show all the existing data sets that have Is Copyable selected in the data set definition. |
Content Description |
This is description associated with the data set content. |
Add a new row (+) |
Click to add another data set to the project. |
Delete a row (-) |
Click to delete a data set from the project. |
ADS projects are not shown in Application Designer project search and cannot be opened in Application Designer.
