Required and Optional Parameters Matrix
The following table shows a matrix of required and optional parameters for Copy and Compare functions.
Terms used in the table:
R — Indicates required parameters for that function.
O — Indicates optional parameters for that function.
Empty cells in the table indicate parameters that are not applicable to that function.
| Function | Parameter | Copy | Compare | |||
From File |
To File |
Database to Database |
From File |
Project |
-PJFF |
R |
-PJTF |
R |
-PJC |
R |
-PJFC |
R |
-PJM |
R |
Connect DB |
-CT |
R |
R |
R |
R |
R |
-CS |
R |
R |
R |
R |
R |
-CD |
R |
R |
R |
R |
R |
-CO |
R |
R |
R |
R |
R |
-CP |
R |
R |
R |
R |
R |
-CI |
O |
O |
O |
O |
O |
-CW |
O |
O |
O |
O |
O |
Target DB |
-TS |
R |
R |
-TD |
R |
R |
-TO |
R |
R |
-TP |
R |
R |
-TI |
O |
O |
-TW |
O |
O |
Log File |
-LF |
O |
O |
O |
O |
O |
Copy |
-FP |
R |
R |
R |
-OVD |
O |
O |
O |
-EXP |
O |
-RST |
O |
O |
O |
-OVW |
O |
O |
Object |
-OBJ |
O |
O |
O |
O |
O |
Copy/Compare |
-CL |
O |
O |
O |
O |
O |
-AF |
O |
O |
O |
O |
O |
-PPL |
O |
O |
O |
O |
O |
-DDL |
O |
O |
O |
O |
O |
-CFD |
O |
O |
O |
O |
O |
-CFF |
O |
O |
O |
O |
O |
-LNG |
O |
O |
O |
O |
O |
Compare |
-FLTR |
O |
O |
-CMT |
O |
O |
-TGT |
O |
O |
-CBY |
O |
O |
-ROD |
O |
O |
-CMTABLE |
O |
O |
-CMXML |
O |
O |
-CMR |
O |
-CROD |
O |
-CRDB |
O |
-NOTKACT |
O |
-CUSTPRJ |
O |
No GUI |
-HIDE |
R |
R |
R |
R |
R |
-QUIET |
O |
O |
O |
O |
O |
-SS |
O |
O |
O |
O |
O |
-SN |
O |
O |
O |
O |
O |
The following table shows a matrix of required and optional parameters for the Merge, Build, Create, and Start functions.
| Function | Parameter | Merge | Build | Create | Start |
Project Definitions |
Project |
Project |
Start App Designer |
Merge |
-PJMG |
R |
Build |
-PJB |
R |
-CFG |
R |
Create |
-PJR |
R |
-PJRCUST |
R |
Connect DB |
-CT |
R |
R |
R |
R |
-CS |
R |
R |
R |
R |
-CD |
R |
R |
R |
R |
-CO |
R |
R |
R |
R |
-CP |
R |
R |
R |
R |
-CI |
O |
O |
O |
O |
-CW |
O |
O |
O |
O |
-LF |
O |
O |
O |
O |
-OBJ |
O |
No GUI |
-HIDE |
R |
R |
R |
O |
-QUIET |
O |
O |
O |
O |
-SS |
O |
O |
O |
O |
-SN |
O |
O |
O |
O |
