Running the Merge Process for Text Definitions
To run the merge process for text definitions:
  1. Launch the Upgrade Definition Type window for a text definition.
  2. Select the definition you want to compare and merge.
  3. Right-click, and select Merge Definition.
  4. Select one of the following:
    • Database. Select this option if the definition to which you are comparing exists in another database. The system prompts you to sign on to the other database.
    • File. Select this option if the definition to which you are comparing exists in a project file. The system prompts you to navigate to the project file.
  5. After selecting what you want to be the result of the final merge, click Save.
