Running a Project PeopleCode Diff/Merge
To run a Project PeopleCode Diff/Merge:
Select Tools, Diff/Merge Project PeopleCode.
Select either:
Database: select this option if you are comparing definitions with another database. The system will prompt you to sign on to the appropriate database.
File: select this option if you are comparing definitions existing in a file. The system will prompt you to navigate to the appropriate file.
