Using Operators to Build the WHERE Clause
This section provides examples for building WHERE Clauses.
Numeric Operators
For any of the numeric operators, select the operator and provide a value.
This example illustrates using the equal operation.
Example Equal Criteria
Between
The Between operator expects an AND keyword in the values field.
This example illustrates using the Between operation
Example Between Criteria
In
In interprets the , (comma) as the separator for the literals.
This example illustrates using the In criteria.
Example In Criteria
Like
Like will implicitly add % (percent sign) with the string.
This example illustrates using the Like operation.
Example Like Criteria
