SOAP Body Section
The body is the XmlDoc where the method is defined. The method AddBody starts the body section of the XML SOAPDoc and must be in the XmlDoc before adding in method sections of the message. Only one body section can be set within one SOAPDoc. This is an optional method and must called only if you need to set any additional attributes for the body section. Otherwise the body section is automatically generated in the XmlDoc.
The SOAP body must be added after you add the SOAP envelope, and before you add any methods.
