Using the Analytic Calculation Engine Classes with Application Engine
All Application Engine programs run on the application engine server. This means your program runs on the application engine server, not the analytic server.
PeopleSoft recommends that you put each of the following methods into its own step when you're creating an analytic calculation using a Application Engine program:
AnalyticInstance Load method
AnalyticInstance Unload method
AnalyticInstance Copy method
AnalyticInstance Delete method (in case of any readable/writable records in the analytic type)
AnalyticModel Recalculate method
CubeCollection SetData method
Also, with the Recalculate method, you should use the Commit after step option.
