Using the Log Fence with PeopleSoft Analytic Calculation Engine
If you set the application log fence to 3 or above, all the detailed messages created on the analytic server to be sent back to the application server are also logged in the analytic server log file.
In addition, if you set the application log fence to 4 or above, all tracing information is logged to the analytic server log file.
