Scheduling a Process Using a Component Interface in Visual Basic
The following example shows how you might schedule a process from outside of PeopleSoft using Visual Basic.
Initializing the component interface:
Dim oSession As New PeopleSoft_PeopleSoft.Session
Dim oBC As ProcessRequest
oSession.Connect(1, "TCHURY072198:7000", "PTDMO", "PTDMO", 0)
'get component from server
Set oBC = oSession.GetComponent("PROCESSREQUEST")
Status = oBC.Get()
Creating a process request:
Properties:
oBC.REQUESTTYPE = "Create" oBC.RUNCONTROLID = "Test" oBC.PROCESSTYPE = "SQR Report" oBC.PROCESSNAME = "XRFWIN" oBC.RUNLOCATION = "PSNT" oBC.RUNDATE = "01/01/2000" oBC.RUNTIME = "09:00:00" oBC.OUTDESTTYPE = "FILE" oBC.OUTDESTFORMAT = "SPF" oBC.OUTDEST = "C:\temp\" -
Method:
ProcessInstance = oBC.Create
Updating a process request:
Properties:
oBC.REQUESTTYPE = "Update" oBC.PROCESSINSTANCE = 10 oBC.RUNSTATUS = "2" -
Method:
oBC.Update
