Public Events for Project Execution Management
This table describes the public events supported by Project Execution Management.
Cloud Product |
Supported Public Event |
Description |
Enabled by Default |
First Release Available |
Callback Service |
| Project Management | Project Status Changes | Signals whenever a project is created or a project status is changed. | No | 17D | REST Service: Projects Operation: Get a Project |
Project Deliverable Status Changes |
Signals whenever a project deliverable status or priority changes. Creating or deleting deliverables doesn't generate signals. |
No |
19A |
REST Service: Deliverables Method: Get a deliverable |
Task Management |
Project Task Progress Status Changes |
Signals whenever a project task progress status changes. Creating or deleting tasks doesn't generate signals. |
No |
19A |
REST Service: Project Plans Resource: Tasks Operation: Get a task of a project |
Task Management |
Project Milestone Completion |
Signals whenever a project milestone is completed. Completing financial tasks that are flagged as milestones doesn't generate signals. |
No |
19A |
Project Resource Management |
Project Resource Request Status |
Signals whenever the status of a project resource request changes, a new request is created in Open or Pending Adjustment status, or resource assignments are readjusted or canceled. |
No |
19B |
REST Service: Project Resource Requests Operation: Get a project resource request |
Project Gate Approver Status Change |
Signals whenever the approval status for a gate is changed by an approver. |
No |
21C |
Project Gate Status Change |
Signals whenever the status of a project gate is changed. |
No |
21C |
REST Service: Project Plans Resource: Gate Approvers Operation: Update |
Project Change Order Changes |
Signals whenever a project change order status or stage or priority changes. Creating or deleting change orders doesn't generate signals. |
No |
23D |
REST Service: Change Orders Resource: Change Order Operation: Update |
Project Issue Status Changes |
Signals whenever a project issue status or priority changes. Creating or deleting issues doesn't generate signals. |
No |
23D |
REST Service: Project Issues Resource: Project Issue Operation: Update |
Project Work Plan Baseline Creation |
Signals whenever a project work plan baseline is created. Setting an existing baseline as the primary baseline doesn’t generate signals. |
No |
23D |
REST Service: Project Plans Resource: Baselines Operation: Create |
