Capture Expenditure Information in Project Costing for Interorganization Transactions
You can capture project attributes on transfer orders, and fulfill these transfer orders from a common or pooled inventory to track costs against a project.
You can capture expenditure information for these material shipment.
From common inventory to a project striped inventory
From common inventory to a project location (expense destination)
Interorganization transfers within a project
The project details associated with the transfer order are listed on the Review Cost Accounting Distributions page.
Interorganization and Intraorganization Transfers
For an interorganization transfer, the shipping organization and receiving organization must be project enabled. In this case, transfer from a project striped inventory to a project striped inventory is supported and the costs are interfaced to PPM.
In the case of an intraorganization transfer, transfer from a common inventory to a project-striped inventory or from a project-striped inventory to a common inventory is supported.
A negative charge is sent for the source or sending organization and a positive charge is sent for the destination organization.
This table lists the accounting events interfaced to PPM for the source and destination organizations.
Source Organization |
Destination Organization |
Transfer Order Issue |
Transfer Order Receipt from In-Transit |
Transfer Order Issue to Expense with Receipt |
Transfer Order Issue to Expense without Receipt |
Transfer Order Direct Transfer Receipt |
Transfer Order Shipment to In-Transit |
Transfer Order Return Shipment |
Transfer Order Return with Scrap |
Transfer Order Direct Transfer Shipment |
Transfer Order Return Receipt |
Transfer Order Intraorganization Receipt |
Transfer Order Subinventory Transfer |
Transfer Order Intraorganization Shipment |
The corresponding accounting lines that are interfaced to PPM are listed here:
Cost Variance
Expense
Freight Expense
Inventory Valuation
Inventory Write Off
Transfer Price Variance
Valuation Unit Transfer Variance
