Periodic Medium/High Volume Updates from External Systems to Oracle Fusion Cloud Product Lifecycle Management
In this use case you might have multiple external sources that post updates to Oracle Fusion Cloud Product Lifecycle Management (PLM) at a set time.
An example of an external source might be a bespoke system that your R&D division uses to maintain an item and its structure.
| Description | Integration Type | Integration Options | Notes |
This use-case scenario usually demands:
Inbound |
Item web services aren't recommended for this use case. |
