Integrate Oracle Fusion Cloud Warehouse Management with Multiple Automation Control Systems in the Warehouse
In this use case, your business must integrate multiple automation systems with Oracle Warehouse Management.
Description | Integration Type | Integration Options | Notes |
Your business must integrate multiple warehouse automation systems with Oracle Warehouse Management. Depending on the type of automation system and their associated automation-control systems capabilities, you should identify:
Planning for the integration requires you to:
For example, pick-to-light, put-to-light, sortation, automatic storage retrieval systems, robotic arms, automated guided vehicles, and automated roaming conveyers. |
Inbound Outbound |
REST API SFTP |
For a large data transaction with some embedded business logic, an integration middle layer is recommended. Explore ready-to-use integration packages if the mapping is uncomplicated or if using Oracle back-end systems. |
