Import Manufacturer Parts
After creating or importing manufacturers, you can import manufacturer parts (MPN). Use the EGP_TRADING_PARTNER_ITEMS_INTF tab to enter MPN data.
The following table defines the key data columns for MPNs:
| Column Type | Data Description |
| Trading Partner Item Number | Manufacturer Part Number |
| Trading Partner Number | Manufacturer Registry ID; obtained from Product Development |
| Trading Partner Type | MANUFACTURER |
| Start Date | The date when this part was added to Product Development; must be earlier than the AML Effectivity Date |
| End Date | The date when this part is no longer active or usable |
Example MPN Data:
| Trading Partner Item Number | Trading Partner Number (Registry ID) | Trading Partner Type | Start Date | End Date |
| FC123 | 1000009 | MANUFACTURER | 2010/01/01 12:00:00 AM | |
| L123 | 1000015 | MANUFACTURER | 2016/01/01 12:00:00 AM | |
| S123 | 1000023 | MANUFACTURER | 2012/01/01 12:00:00 AM |
