Analysis Using Maintenance Work Orders
Use the Maintenance table to review and adjust maintenance work orders.
The Maintenance table contains maintenance work orders for resources that are associated with the respective assets. It’s only visible if you select the schedule option Consider maintenance downtime in manufacturing schedule.
You can filter records by work center or resource. When you select a maintenance work order in the table, its operations are highlighted in the Gantt chart. Click the Clear Pegging Highlights button to remove the highlighting. For more information about the maintenance work order, you can click the View Work Order icon in the Work Order column to view the maintenance work order in the Supply Chain Execution work area.
Analyze
Review and analyze maintenance work orders and their impact by checking the start and end times to understand where they’ll be scheduled. The work center resources for these orders are linked to assets and can have different types and subtypes, such as Corrective or Emergency.
Adjust
You can edit the Start Time Override field to influence where the maintenance work order is placed.
The Start Time Override isn't released to the manufacturing application.
