Spoke systems (also called source systems) enable you to identify the source of data
imported into or published from the Oracle Fusion Cloud application.
Data Selections
Use Spoke system filters to manage item entities and data that are published. The
information in the table will help you set the scope of your integration by
describing the entities and data you should select.
| Data Selections |
Options |
| Item entities |
- Publication Maps: Lets you filter the attributes that are
needed for downstream applications. It's preferred because
it generates a smaller payload only for the applicable
attributes. See Set Up Publication
Options for a Spoke System for information about
the options that control the publication of item
objects.
- Entities Selector: Lets you publish system IDs that are
usually required for data-warehouse applications but aren't
usually applicable to other integrations. See Rules and Rule
Sets for information about selecting
entities.
| Data criteria |
- Selection Criteria: Lets you filter items based on business
entities, such as item class and item organization. See the
Publish Options section in Product Spoke
Systems for more information about defining
publication options, such as item class, trading partner
item, and catalog publication criteria.
- Item Validation Rules: Lets you filter items using business
validation rules. You can configure business rules to
validate item data at a more granular level than you can
with selection criteria. See the Validation section in Rules and Rule
Sets for information about defining validation
rules.
