Perform Complex Data Analysis Using Multidimensional, Multiple Source Data
In this use case your goal is to maintain item costs in Oracle Cost Management by using various data-analysis tools.
| Description | Integration Type | Integration Options | Notes |
You're a large multinational manufacturing company. You use Oracle Cost Management to maintain your item costs. Item costs are used for various reasons. Some common ones include exporting costs to spreadsheets or data warehouses for doing various types of analysis. Other use cases include importing transactions to calculate the actual or average costs in Oracle Fusion and then exporting for downstream analysis. Usually, this scenario demands:
Outbound | Business Intelligence Cloud Connector (BICC) can be used to perform data extraction by accessing the public view objects (PVOs). |
