Frequent Low-Volume Updates from External Systems to Oracle Fusion Cloud Product Lifecycle Management
In this use case you might have multiple external sources that update often and post the updates to Oracle Fusion Cloud Product Lifecycle Management.
An example of an external source might be your compliance system.
| Description | Integration Type | Integration Options | Notes |
This use-case scenario usually demands:
Inbound |
