Migrate Master Data from an ERP System to Oracle Fusion Cloud Warehouse Management
In this use case, your business must integrate many master data entities required for warehouse setup into Oracle Warehouse Management for the first time and maintain them on an ongoing basis.
Description | Integration Type | Integration Options | Notes |
As a company, you've recently started implementing an execution system like warehouse management for your distribution centers. You must integrate many master data entities required for warehouse setup into Oracle Warehouse Management for the first time and maintain them on an ongoing basis. Back-end enterprise resource planning (ERP) or warehouse management systems, which might be Oracle or external applications, would require a great deal of planning, mapping, and data transformations to suit the format specifications of Oracle Warehouse Management. Master data, such as items, vendors, locations, facilities, supplier barcodes, and metadata could be affected. Usually, this scenario demands:
Inbound |
REST API SFTP |
For a large data transaction with some embedded business logic, an integration middle layer is recommended. Explore ready-to-use integration packages if the mapping is uncomplicated or if using Oracle back-end systems. |
