Work Order Operation Material Reference Designator REST Endpoints
Manufacturing/Discrete Work Orders/Work Order Materials/Work Order Operation Material Reference Designator
A reference designator identifies where work order operation material is used in an assembly. For example, a reference designator can identify that a component is used at position P1 or location L2.
Get all reference designators
Method: get
Path: /fscmRestApi/resources/11.13.18.05/workOrders/{WorkOrderId}/child/WorkOrderMaterial/{WorkOrderOperationMaterialId}/child/WorkOrderOperationMaterialReferenceDesignator
Get one reference designator
Method: get
Path: /fscmRestApi/resources/11.13.18.05/workOrders/{WorkOrderId}/child/WorkOrderMaterial/{WorkOrderOperationMaterialId}/child/WorkOrderOperationMaterialReferenceDesignator/{WoOperMtlReferenceDesignatorId}
