Before You Begin
This 15-minute tutorial shows you how to use Database Configuration Assistant (DBCA) to clone a remote pluggable database (PDB) into a container database (CDB).
Background
In Oracle Database 18c, cloning a remote PDB requires several commands to be executed.
What Do You Need?
- Oracle Database 19c installed
- Two CDBs:
ORCLwithPDB1andCDB19, both in archivelog mode. You can use the dbca.sh shell script to createCDB19. Download the shell script to the labs directory created on your server/home/oracle/labs. Replace the password in the shell script by your own complex password. PDB relocation PDB and remote PDB clone operations with DBCA do not support Oracle Managed Files (OMF) enabled CDB. Verify that the PDB to be cloned does not use OMF. HRschema installed inPDB1as an example of application tables. If you want to use theHR.EMPLOYEEStable, use the hr.sql. Download the SQL script to the labs directory created on your server/home/oracle/labs.In the script, update the password of the user connected to the database.
Prepare
the
PDB Before Cloning
- Log in to
PDB1inORCLasSYSTEM.sqlplus system@PDB1
Enter password: password - Use the hr.sql
script to create the
HRuser andEMPLOYEEStable inPDB1.@/home/oracle/labs/hr.sql - Verify that
PDB1contains theHR.EMPLOYEEStable.SELECT count(*) FROM hr.employees;
COUNT(*) ---------- 107 - Connect to
ORCLasSYSTEM.CONNECT system@ORCL Enter password: password
- Create a common user in
ORCL, used in the database link automatically created inCDB19to connect toORCLduring the cloning operation.CREATE USER c##remote_user IDENTIFIED BY password CONTAINER=ALL;
- Grant the privileges.
GRANT create session, create pluggable database TO c##remote_user CONTAINER=ALL;
- Quit the session.
EXIT
Use
DBCA to Clone a Remote PDB
In this section, you use DBCA in silent mode to clone PDB1
from ORCL as PDB19 in CDB19.
- If
CDB19does not exist, launch the/home/oracle/labs/dbca.shshell script. The script creates the CDB with no PDB.In the script, update the password of the user connected to the database./home/oracle/labs/dbca.sh
- Launch DBCA in silent mode to clone
PDB1fromORCLasPDB19inCDB19.dbca -silent -createPluggableDatabase -createFromRemotePDB -remotePDBName PDB1 -remoteDBConnString ORCL -remoteDBSYSDBAUserName SYS -remoteDBSYSDBAUserPassword password -sysDBAUserName sys -sysDBAPassword password -dbLinkUsername c##remote_user -dbLinkUserPassword password -sourceDB CDB19 -pdbName PDB19
Prepare for db operation 50% complete Create pluggable database using remote clone operation 100% complete Pluggable database "PDB19" plugged successfully. Look at the log file "/u01/app/oracle/cfgtoollogs/dbca/CDB19/PDB19/CDB19.log" for further details.
Check
that the PDB Is Cloned
- Connect to
CDB19asSYS.sqlplus sys@CDB19 AS SYSDBA Enter password: password
SHOW PDBS
CON_ID CON_NAME OPEN MODE RESTRICTED ---------- ------------------------------ ---------- ---------- 2 PDB$SEED READ ONLY NO 3 PDB19 READ WRITE NO - Check that
PDB19contains theHR.EMPLOYEEStable as inPDB1.CONNECT hr@PDB19 Enter password: password
SELECT count(*) FROM employees;
Clean
Up the PDB Cloned
- Connect to
CDB19asSYS.CONNECT sys@CDB19 AS SYSDBA Enter password: password
- Close
PDB19.ALTER PLUGGABLE DATABASE pdb19 CLOSE;
- Drop
PDB19.DROP PLUGGABLE DATABASE pdb19 INCLUDING DATAFILES;
- Quit the session.
EXIT
Clone
PDBs using DBCA in Silent Mode
