Using SRVCTL Help
Learn about how to use context sensitive help with SRVCTL commands.
To see help for all SRVCTL commands, from the command line enter:
srvctl -help
To see the command syntax and a list of parameters for each SRVCTL command, from the command line enter:
srvctl command (or verb) object (or noun) -help
When you request online help for a command using -help, SRVCTL prints the full words for each parameter. You can obtain the single-letter equivalents, where applicable, by adding the -compatible parameter after the -help parameter. For example:
$ srvctl config database -help -compatible
The preceding command prints usage information for the srvctl config database command, listing all parameters as full words followed by their single-letter equivalents in parentheses, where applicable.
To see the SRVCTL version number enter:
$ srvctl -version
