About Adding Nodes Using Cloning in Oracle RAC Environments
You can use cloning to add nodes in Oracle RAC environments.
The cloning procedures assume that you have successfully installed and configured an Oracle RAC environment to which you want to add nodes and instances. To add nodes to an Oracle RAC environment using cloning, first extend the Oracle Clusterware configuration, then extend the Oracle AI Database software with Oracle RAC, and then add the listeners and instances by running the Oracle assistants
The cloning script runs multiple tools, each of which may generate its own log files. After the clone.pl script finishes running, you can view log files to obtain more information about the cloning process.
Related Topics
