5.12 Viewing and Querying SQL Property Graphs Using SQL Developer
Using SQL Developer 23.1, you can view all the SQL property graphs existing in your database schema by expanding SQL Property Graphs under the Property Graph node in the Connections navigator.
Figure 5-1 SQL Property Graphs in SQL Developer
Description of "Figure 5-1 SQL Property Graphs in SQL Developer"
The following steps show an example for running graph queries on a SQL property graph:
Parent topic: SQL Graph Queries
