17.3.8 Setting the Edge Embedding Production Method
By default, the edge embedding is computed by combining the source vertex
            embedding, the destination vertex embedding and the edge features. You can manually set
            these by setting the
               EdgeCombinationMethod with booleans
            parameters:
               opg4j> import oracle.pgx.config.mllib.edgecombination.EdgeCombinationMethods
opg4j> var method = EdgeCombinationMethods.concatEdgeCombinationMethod(useSourceVertex, useDestinationVertex, useEdge)
opg4j> var model = analyst.supervisedEdgeWiseModelBuilder().
         setVertexInputPropertyNames("vertex_features").
         setEdgeInputPropertyNames("edge_features").
         setEdgeTargetPropertyName("labels").
         setEdgeCombinationMethod(method).
         build()import oracle.pgx.config.mllib.edgecombination.EdgeCombinationMethod;
import oracle.pgx.config.mllib.edgecombination.EdgeCombinationMethods;
EdgeCombinationMethod method = EdgeCombinationMethods.concatEdgeCombinationMethod(useSourceVertex, useDestinationVertex, useEdge);
SupervisedEdgeWiseModel model = analyst.supervisedEdgeWiseModelBuilder()
    .setVertexInputPropertyNames("vertex_features")
    .setEdgeInputPropertyNames("edge_features")
    .setEdgeTargetPropertyName("labels")
    .setEdgeCombinationMethod(method)
    .build();from pypgx.api.mllib import ConcatEdgeCombinationMethod
method_config = dict(use_source_vertex=True,
    use_destination_vertex=False,
    use_edge=True)
method = ConcatEdgeCombinationMethod(**method_config)
params = dict(edge_target_property_name="labels",
              vertex_input_property_names=["vertex_features"],
              edge_input_property_names=["edge_features"],
              edge_combination_method=method,
              seed=17)
model = analyst.supervised_edgewise_builder(**params)
