Building an Unsupervised Anomaly Detection GraphWise Model Using Partitioned Graphs
You can build an Unsupervised Anomaly Detection GraphWise model using partitioned graphs which have different providers and features.
opg4j> var model = analyst.unsupervisedAnomalyDetectionGraphWiseModelBuilder().
setVertexInputPropertyNames("vertex_provider1_features", "vertex_provider2_features").
build()
UnsupervisedAnomalyDetectionGraphWiseModel model = analyst.unsupervisedAnomalyDetectionGraphWiseModelBuilder()
.setVertexInputPropertyNames("vertex_provider1_features", "vertex_provider2_features")
.build();
params = dict(vertex_input_property_names=["vertex_provider1_features", "vertex_provider2_features"])
model = analyst.unsupervised_anomaly_detection_graphwise_builder(**params)
It is possible to select which providers you want to train or infer on:
build()
.build();
If you wish to control the flow of the embeddings at each layer, you can enable or disable the connections of interest. By default all the connections are enabled.
opg4j> var convLayerConfig = analyst.graphWiseConvLayerConfigBuilder().
setNumSampledNeighbors(25).
useVertexToVertexConnection(true).
useEdgeToVertexConnection(true).
useEdgeToEdgeConnection(false).
useVertexToEdgeConnection(false).
build()
build()
GraphWiseConvLayerConfig convLayerConfig = analyst.graphWiseConvLayerConfigBuilder()
.setNumSampledNeighbors(10)
.useVertexToVertexConnection(true)
.useEdgeToVertexConnection(true)
.useEdgeToEdgeConnection(false)
.useVertexToEdgeConnection(false)
.build();
.setConvLayerConfigs(convLayerConfig)
.build();
conv_layer_config = dict(num_sampled_neighbors=25,
activation_fn='tanh',
weight_init_scheme='xavier',
neighbor_weight_property_name=weightProperty,
vertex_to_vertex_connection=True,
edge_to_vertex_connection=True,
vertex_to_edge_connection=False,
edge_to_edge_connection=False)
conv_layer = analyst.graphwise_conv_layer_config(**conv_layer_config)
params = dict(vertex_input_property_names=["vertex_provider1_features", "vertex_provider2_features"],
conv_layer_config=[conv_layer])
