Viewing and Querying SQL Property Graphs Using SQL Developer
Using SQL Developer 23.1, you can view all the SQL property graphs existing in your database schema by expanding SQL Property Graphs under the Property Graph node in the Connections navigator.
Description of image follows
The following steps show an example for running graph queries on a SQL property graph:
  1. Click on any SQL property graph.
    This opens a SQL worksheet in another tab.
  2. Run one or more graph queries in the SQL worksheet.
    For example:
