Using Drag and Drop for Code Generation
The Drag-and-Drop Code Generation feature simplifies how various programming languages interact with Oracle databases. It enables you to drag and drop database objects into a Java file, which automatically generates the corresponding Java code, including all the logic required to execute queries on the Oracle database.
Additionally, you can drag an entire database connection from the Connections panel into your Java file to quickly generate the connection string or complete JDBC API code, streamlining your development process.
