Load a Model Using the Vector Database Console
Follow these steps to load a pre-configured model using the vector database console.
  1. From the vector database console, select the Models tab.
    This will take you to a list of available pre-configured models that you can use to vectorize your data.
  2. Select the three dots context menu icon icon in the tile of your desired model, then click the Load option.
    You will be prompted to confirm your choice. Once selected, the model will display a status of Loading until it becomes Available.
