19.15.5 Connection management
Connections are medium of communication with your Oracle Autonomous AI Database. It contains information that helps in authenticating with database instances and accessing data from a spreadsheet.
The connections feature lets you manage and connect to multiple Autonomous AI Databases with a single add-in. Multiple connections can be created. Each time you start the Add-in for Excel, use Connections to connect to the databases. However, only one connection can remain active at a given time.
The connection panel lets you connect to the Autonomous AI Database through a connection where you provide the login credentials and access the Autonomous AI Database.
- Create or delete multiple connections using a single add-in.
- Share connection information by exporting and importing connection information to a file.
- View existing connections.
Selecting Connections opens the Connections wizard.
This is an implicit type of connection. Refer to Authenticate using Implicit connection to understand more about implicit connection.
- Add Connection: Select Add Connection to Add a Connection. Refer to Add a connection section for more details.
- Export Connection: Select Export Connection to export connections. Refer to the Share a connection section for more details.
- Import Connection: Select Import Connection to launch the import wizard to choose a connection file. These files are in JSON format. Refer to the Share a connection section for more details.
