Load a Model Using the Vector Database Console
Follow these steps to load a pre-configured model using the vector database console.
  1. From the vector database console, select the Models tab.
    This will take you to a list of available pre-configured models that you can use to vectorize your data.
  2. Select the three dots img/actions.jpg icon in the tile of your desired model, then click the Load option.
    You will be prompted to confirm your choice. Once selected, the model will display a status of Loading until it becomes Available.
