17.6 Work with Projects
A project is the top-level container, which can include multiple folders to organize your data flows or work flows into logical groups.
The Projects page displays all the existing projects, which includes projects created by all users not just the logged in user.
You can perform the following operations on a Project folder:
- View Details
- Edit the name
- Export the Project. See Export Objects.
- Delete
Creating a Project
To create a new project:
- Click Create Project on the Projects page.
- On the Create Project page, provide a project name.
- Click Create.
After creating the project, you're redirected to the Projects page.
Viewing Project Details
On the Projects page, select a project and click View Details from the project's Actions icon (
) or select a project to open its details page. The left panel displays all the resources associated with the selected project such as data loads, data flows, workflows, variables, schedules, and jobs.
Deleting a Project
Be sure to review all contained resources before you delete the project.To delete a project, on the Projects page, select Delete from the Actions icon (
) for the project you want to delete or select a project to open its details page, and then click Delete.
In the Delete Project dialog, click Delete to confirm the delete operation.
