Using Parameter-Level Keywords and Values
A parameter begins with the param=<NAME>
keyword followed by a number of parameter keywords. It ends when
another param or service keyword, or
end-of-file is encountered. The parameters can be in any order
after the param=<NAME> keyword.
The following table contains the guidelines for use of the parameter-level keywords and acceptable values for each.
Table 2-4 Parameter-Level Keywords and Values
| Keyword | Values |
param
Any parameter name |
type
access
count
Maximum number of occurrences (default is 1). The value for unlimited occurrences is 0. Used only by the Repository Editor to format test screens. |
Subtype
If the parameter is of view32 type, this field specifies the view structure name. Otherwise, this field is ignored. All the sub-parameters of nested view32 are enclosed in parentheses.
Parent topic: Syntax of the Bulk Loader Data Files
