Example 2 : Using a covering index in a query plan with index scans and index predicates
Fetch the id and income of users whose state is CA and whose income
is greater than
2000.
SELECT id, income FROM Users u WHERE u.address.state = "CA" AND income > 2000
Query execution
plan:
"iterator kind" : "RECEIVE",
"distribution kind" : "ALL_SHARDS",
"input iterator" :
"iterator kind" : "SELECT",
"FROM" :
"iterator kind" : "TABLE",
"target table" : "users",
"row variable" : "$$u",
"index used" : "idx_state_city_income",
"covering index" : true,
"index row variable" : "$$u_idx",
"index scans" : [
"equality conditions" : {"address.state":"CA"},
"range conditions" : {}
"index filtering predicate" :
"iterator kind" : "GREATER_THAN",
"left operand" :
"iterator kind" : "FIELD_STEP",
"field name" : "income",
"input iterator" :
"iterator kind" : "VAR_REF",
"variable" : "$$u_idx"
"right operand" :
"iterator kind" : "CONST",
"value" : 2000
"FROM variable" : "$$u_idx",
"SELECT expressions" : [
"field name" : "id",
"field expression" :
"field name" : "#id",
"input iterator" :
"input iterator" :
Explanation of the query execution plan :
- The root iterator of this query plan is a RECEIVE iterator with a single child (input iterator) that is a SELECT iterator. The only property of the RECEIVE iterator in this example, is the distribution kind whose value is ALL_SHARDS.
- The index
is used here and this is a covering index as all the fields in the SELECT expression can be fetched only using the index entries. - The index scan property contains the start and stop conditions that define the index
scans to be
performed.
In this example, only one index scan will be performed. The conditions correspond to the predicates u.address.state = "CA" from the query. Specifically, the starting index entry must have the value CA on the"index scans" : [ { "equality conditions" : {"address.state":"CA"}, "range conditions" : {} } ]
address.state
field. All subsequent entries must have CA as the value of theiraddress.state
field, and the scan will stop as soon as an entry with a different state value is encountered. Although the query contains a range predicate on income, this predicate does not appear as a range condition of the index scan. This is because there is no equality condition on theaddress.city
field that appears before the income field in the index definition, and as a result, the income predicate cannot be used to determine the boundaries of the scan. Instead, the income predicate can be used as anindex filtering predicate
that is applied on every index entry produced by the index scan. - The
evaluates the filter criteria on theincome
field. Using the greater than operator the filter condition is evaluated."index filtering predicate" : { "iterator kind" : "GREATER_THAN", "left operand" : { "iterator kind" : "FIELD_STEP", "field name" : "income", "input iterator" : { "iterator kind" : "VAR_REF", "variable" : "$$u_idx" } }, "right operand" : { "iterator kind" : "CONST", "value" : 2000 } }
- The index row variable is
$$u_idx
which is the name of a variable ranging over the index entries produced by the TABLE iterator. Every time a new index entry is produced by the index scan, the$$u_idx
variable will be bound to that entry. - When the FROM iterator is a TABLE iterator, the FROM variable is the
same as either the index row variable or the row variable
of the TABLE iterator, depending on whether the used index is covering or not. In
this example, the FROM variable is same as the index row variable
$$u_idx
) as the index is covering because all the fields in the SELECT expression can be evaluated only using the index entries. - This index row variable (
$$u_idx
) will be referenced by iterators implementing the other clauses of the SELECT expression. - In the SELECT expression, two fields (
id
andincome
) are fetched. These correspond to two field names and field expressions in the SELECT expression clause.
For every field to be fetched by the SELECT expression, the field expression is computed by a FIELD_STEP iterator. The FIELD_STEP iterator extracts and returns the value of a field ({ "field name" : "id", "field expression" : { "iterator kind" : "FIELD_STEP", "field name" : "#id", "input iterator" : { "iterator kind" : "VAR_REF", "variable" : "$$u_idx" } } }
id
as shown above) from the records produced by its input iterator. The same is done for every field to be fetched in the SELECT expression.
