SYS.V$OPT_MAX_CMD_FREELIST_CNT
This view contains data about the size of the free list of the SQL compiled command cache.
Usage with TimesTen Scaleout
This view contains data for the local element.
Usage with TimesTen Classic
This view contains data for the database to which the application is connected. It has the same contents as SYS.GV$OPT_MAX_CMD_FREELIST_CNT.
Related view
Columns
See ttOptGetMaxCmdFreeListCnt in the Oracle TimesTen In-Memory Database Reference for information on the columns in this view, including the column name, data type, and description.
In addition to these columns, the view contains the elementId column of type TT_INTEGER NOT NULL that contains the element id for the element to which the application is connected. Ignore this column in TimesTen Classic.
