4.1.2 Resetting the ILOM Using the ILOM Remote Console
If it is not possible to connect to the ILOM using SSH, then log in to the ILOM remote console. The following procedure describes how to reset the ILOM using the remote console.
- Log in to the ILOM remote console.
- Select Reset SP from the Maintenance tab.
- Click Reset SP.
Parent topic: Resetting a Non-Responsive ILOM
