4.2.4 Resetting the ILOM Using the SP Reset Pin on Oracle Exadata Database Machine X2-2 Servers and Exadata Storage Servers
If you could not connect to the ILOM using SSH, the remote console, or IPMItool on the Oracle Exadata Database Machine X2-2 server or Exadata Storage Server, then press the SP reset pin. The following procedure describes how to reset the ILOM using the SP reset pin.
- Obtain a small, non-conductive stick.
- Go to the rear of the rack.
- Locate the SP reset pin opening. The SP reset pin opening is the first opening to the right of the NET MGT port.
- Insert the stick into the opening and press the pin.
Parent topic: Resetting a Non-Responsive ILOM
