- Maintenance Guide
- General Maintenance Information
- Replacing a Disk Controller Battery Backup Unit
- Replacing a Disk Controller BBU on a Database Server
- Step 1: Prepare the Disk Controller BBU for Removal
- Preparing Systems with Remote Mount BBU
1.9.1.1.1 Preparing Systems with Remote Mount BBU
Describes how to prepare to remove the disk controller BBU on systems with remote mount BBU.
If your system does not have a remote mount BBU, see Preparing Systems That Do Not Have a Remote Mount BBU.
- Log in as the
root
user. - Get the version of the image that is running on the server in the rack that requires service.
# imageinfo -ver 11.2.3.2.1.130302
The version is the first five parts, such as
11.2.3.2.1
in the example. The last part is the image date. - Prepare the disk controller BBU for removal.
If you are running version 12.1.2.1.0 or later:
- Drop the disk controller BBU for replacement:
DBMCLI> alter dbserver bbu drop for replacement
- Verify the BBU status has been updated.
DBMCLI> list dbserver attributes bbustatus - dropped for replacement
If you are running versions between 11.2.3.3.0 and 12.1.2.1.0:
- Drop the disk controller BBU for replacement.
# /opt/oracle.cellos/compmon/exadata_mon_hw_asr.pl -drop_bbu_for_replacement
- Verify the status has been updated.
# /opt/oracle.cellos/compmon/exadata_mon_hw_asr.pl -list_bbu_status BBU status: dropped for replacement.
If you are running version 11.2.3.2.x:
- Locate the server in the rack being serviced, and turn on the indicator light.
Exadata Storage Servers are identified by a number 1 through 18, where 1 is the lowest Storage Server in the rack installed in RU2, counting up to the top of the rack.
Exadata Database Nodes are identified by a number 1 through 8, where 1 is the lowest most database node in the rack installed in RU16.
Turn on the locate indicator light for easier identification of the server being serviced. If the server number has been identified, then the Locate Button on the front panel may be pressed. To turn on the indicator light remotely, use any of the following methods:
From a login to the CellCli on Exadata Storage Servers:
CellCli> alter cell led on
From a login to the server's ILOM:
-> set /SYS/LOCATE value=Fast_Blink
root
account:# ipmitool chassis identify force Chassis identify interval: indefinite
- Check that HBA can see the battery and its current status.
If you are running on Solaris, use
/opt/MegaRAID/MegaCli
in place of/opt/MegaRAID/MegaCli/MegaCli64
in the commands below.# /opt/MegaRAID/MegaCli/MegaCli64 -adpbbucmd -a0
The default output should show that the battery is still visible and may show low voltage or other issues depending on the fault. It may return an error reading the BBU if it is hard failed and no longer accessible to the HBA.
- Verify the current cache policy for all logical volumes.
# /opt/MegaRAID/MegaCli/MegaCli64 -ldpdinfo -a0 | grep BBU
The default cache policy should be
WriteBack
for all volumes. If the battery is functioning normally it will report as current cache policyWriteBack
. However if it is failed it may report current cache policy asWriteThrough
. - Set the cache policy for all logical volumes to
WriteThrough
cache mode, which does not use the battery.# /opt/MegaRAID/MegaCli/MegaCli64 -ldsetprop wt -lall -a0
- Verify the current cache policy for all logical volumes is now
WriteThrough
.# /opt/MegaRAID/MegaCli/MegaCli64 -ldpdinfo -a0 | grep BBU
Parent topic: Step 1: Prepare the Disk Controller BBU for Removal
